1 - 19 of 19 Posts
Problem and having trouble getting anything to work. I closed the trunk on my 1500 and it will not open. The lock mechanism seems to be working fine. I watched a you tube video of a guy using a screw driver to push on linkage to open. By pushing it mine does nothing. Saw another place to take a coat hanger bend a hook and pull on bar. Well I have tried and can not seem to get hooked around a bar. Help please!!
Trunk Will Not Open
There is no need to remove the panel under the trunk, you can't see the release rod from there. BTW...there are four (4) screws on that panel.
If you want to send me your email address (by pm), I will send you a detailed message (with a picture of the tool you need to make from a coat hanger) regarding how to open the trunk.
I think I sent a pm. My computer is acting up not sure if it went or not. If you don't get it please let me know.
So what would be the problem with posting it on the forum?
Received it and sent you an email message with an attached document that included a picture.
Got it thanks will be back in garage today trying to get it open. Thanks.
got a funny for you.
the Piaggio scooter that we just got?
well, to open the hatch, you insert key, push down hard, and turn CCW
to open the gas cap cover, insert key, push down hard, turn CW
now hell the heck to you open the friggin seat? I tried and tried the push CW over and over and over......
in the manual, there is one very tiny line in 8 point font that says "Press button on Key FOB"
yup, if the battery is dead or missing, you will not get that seat unlocked.
Found the "how to" on a Piaggio forum, and the thread that came up was:
" hey guys, I took the battery out for the winter, and now I can get the seat unlocked"
well, the battery is underneath the seat.... if you remove the battery, you put something in between the seat and the latch, cause if you don't, you are screwed.
That seat latch is electric, no manual control to it.
to get to the latch from the bottom of the bike is a PITA, and fraught with damage to the latch mechanism.
Just want to public say thank you to DBohrer I got my trunk open. Found that the linkage is broken, but I am inside and can now repair it. Thanks again.
I recall my friends father having a vespa with the same design flaw. There was a way to open his but i don't know if i remember correctly or not. It seems like he had to back feed power somehow. Maybe through one of the lights? I know he fed wires from an external battery to somewhere on the bike to get the seat up.
GhostRider, , ,glad to hear you got to the problem. I'm curious though, would taking the screws outta the bottom of the trunk led you to the same area so you could fix the problem?
If not, , ,I'm gonna have to make friends with DBorher to get a peek at his magic docs/pics. I hope the linkage on my 27 yr old ride stays working, , , but chances are slim.
Discussion Starter #13
Pulling bottom panel only lets you see top of levers the part you have to get to can't be seen.. DBorher sent me a pic of a tool to make and instructions on how to use it. I have mine straightened out. I fought it for hours and got no results until he told me the right way to open it.
Too bad that info it not available to anyone needing it.
But if you put that out on an open forum it pretty much makes locking your trunk useless now doesn't it? You are telling everyone how to get into it without that latch.
After reading this thread yesterday I did a google search and found all the information needed. How to bend the wire (with angle and length included), how to use the wire and most importantly how the latch and lock works. Now, if I just had a 1500 to test it on.>:)
A thief will use a screwdriver or a hammer, whichever is more convenient, to break into a plastic box. They won't take the time to read the instruction, let alone bother using them.
Locks only keep honest people out.
1 - 19 of 19 Posts
