If this is for your speaker fitting mentioned in another post, you don't have to remove the trunk. The screws for the speaker pods can be removed from below the pods. There are 2 hidden screws which means you need to remove the trunk lid plastic liner to get to them. The hole for the wires to pass through the speaker pod can be drilled without removing the trunk.
