a jig.
I am in a position to MAYBE start R&D and possibly production of the drilling jig for 1000 and 1100 exhaust studs.
And yer like..."Huh?"
Well her is the situation, you need to pull the exhaust off yer old Wing, in the process one of the studs breaks off either flush or down in the head. The only option is to drill it out. But how do you keep the drill from walking of the stud and into the aluminum head?
Well the idea isn't new it just hasn't been done for our specific application.
A jig, that bolts onto the head using the exhaust studs, that features a drill bushing that guides your drill keeping it centered in the stud, so that you drill the stud and only the stud out. You'd then pick out the old bot threads from the head as deep as you can to ensure proper alignment of your tap, use a tap to clean out the rest of the stud threads out and yer good as new with a replacement stud.
The jig would consist of a machined aluminum plate with removable and interchangeable drill guides. Just put the proper guide ont he position of the broken stud and use the remaining studs to bolt the jig in place. The parts would all be machined by hand to insure exact tolerances. The jig would locate your drill within one thousandth of an inch of the center of the stud. The guides would feature pressed in hardened steel inserts which in the very unlikely event that one would wear out it could be pressed out and a new one pressed in.
Such jigs are already around for many automotive applications. But to my knowledge such a thing does not exist specifically for the old Wings. I'm thinking it would be damned handy for the guys who restore these old bikes.
So what I'm wondering about is the marketability of such an item.
Obviously it isn't for every tool box. But would any of you be interested in having such a contraption? If so what would you be willing to pay for it.
a jig.
