I am not sure on the SE with the Honda CB, my guess is that it is at the back of the radio itself, pull off the small storage tray above it and look down there and see if you can see it??
I wouldn't expect a connection under the seat
I have a Aspencade, so have a J&M CB installed, when I installed it, I put a connection in the trunk to make it easy to check the SWR.
Good Luck
May find someone else here that can tell you where the SE has that connection
