I want to install LEDs replacing all my incandescent bulbs on my '84 GL1200 Interstate. I understand I will need to replace the turn signal and emergency flasher relays (same part # on my '84 GL1200).
I have several questions:
1) Where are these relays located (under the false gas tank)?
2) How many pins (3 or 4)?
I have found I believe is designed for the flashers (CF 13 JL-02 Flasher for LED 12V
0.02A-20.0A).
3) Do I have to remove the false gas tank to replace these units?
4) Do I also need to replace the turn signal cancel unit with an electronic (LED) unit?
0.02A-20.0A).
