My 83I is blowing the brake light/turn canceling fuse. I have isolated it down to when the turn signal cancelsit blows. I have looked at the wiring around the false tank and can see nothing wrong. Signals work fine. Is there a way to disengage the turn canceling on this motorcycle? Does anyone have a wiring diagram for this system? Any help will be greatly appreciated.
Thanks,
Billy
Hey bmoore106 I remember reading somthing in one of my Mags about cutting the white wire that leads to it but I think that was on the 1800s just hold out somebody will help you out
You will have to check the cancelling unit as it sounds like a wire shorting out inside (not uncommon on the 4 cylinder Wings). It's inside the steering tube and you get to it by unscrewuing it from the bottom of the steering yolk.
· Postpubescent member
NO! NO.... NOT THE WHITE WIRE!!
I'll look into that. I found a thread for the 1800 and thought that's what wingwarrior was talking about. I have not cut any wires, butI am interested in disabling this feature.
Thanks,
Billy
Hi Billy. Sometimes you get corrosion in the tube and it causes problems with the canceller unit. You'll likely be checking this anyway.
Hate to say it, but this was quite odd. The fuse was blowing everytime the signal would cancel. I looked at everything in the system. Could find no problems. While l had the seat and trunk removed I noticed a wire for the trunk light bar was smashed between the trunk mount and the trunk brace. Light bar was working fine. Removed and respliced the damaged wire. Its been several days and several hundred miles and all is working right. Signal cancels and fuse does not blow. I guess there must have beena small short in the wire causing just enough extra draw when the siganl canceled to blow the fuse. Thanks for everyone's advice and help.
Billy
