Hey all,
The question I'm asking has been answered on this forum, however, I can't find it using the search. So, my turn signals flash very, very fast. Whats the fix? Also, What is the recomended Flasher Unit for a 1981 GL1100. The one I'm using is 2 prongs with a wire left over. I read on this forum which one to use and which wires go where. Can someone help?
teacher
First look for a burned out bulb.. Without the resistance from the bulb filament, the amperage is higher which causes the flasher to heat up quicker and will make it flash very fast..
Thank you for answering,\
Just checked and all bulbs are good. I changed out the flasher unit and now turn signals work properly. However, there are 3 prongs on the flasher unit labled "X", "L", and "P" and 3 wires to connect. One is gray, another is green and the last one is white w/green. Which one goes where. I have a Haynes manual but it does not indicate which wire goes to which terminal. I can guess Gray goes to X, White w/green goes to L and Green goes to P?
teacher
If you already have it working then why worry about it? Some people use car flasher units on their gl1100s and have no problems.
hey 03silver,
Your right!:clapper: Problem solved. I'll move on to other problem.
ride on,
teacher
