I would divide the halves and soak the switch with the cleaner if it worried me but as it doesn't I just live with it.How the switch lubricant applied? Do I take apart the assembly as I suspect and spray it onto the switch? is that all that's required?
Spraying with what? The lubricant? :?I have had pretty good luck just spraying into the switch from where the lever is.
