1 - 13 of 13 Posts
Hello everyone, I am glad I found this site. I recently picked up a 1982 Interstate that had been wrecked in the front. I rebuilt the bike as a custom, but I have a problem with the turn signals. The lights come on, but they won't blink. My question is, is there a way to bypass the speed sensor in the speedo? The speedo was smashed, so I fixed up the bike with a custom speedo. I have tested all the individual componets and they all seem fine. Or is the automatic turn canceling unit going to give me problems? Any advice at this point would be great.
Thanks in advance !!!
Might be the flasher needs replacing? I really don't know but sometimes the little things get overlooked.
By the way,welcome to the board. I'm new here too, and from what I've seen and read so far, I think this just might be the place to be!!!
Older and Wiser
verybadmonkey wrote:
I think the flasher is OK. I jumped it straight to the power wire on the rear signals, and they flashed then. Too bad it was both at the same time.
You've just proved that the flasher unit is faulty!
Welcome to the forum, verybadmonkey& Allen. :waving:
G
Hey verybadmonkey :waving: Welcome to the forum and visit often. :clapper:
Hello again, and thanks for the warm reception.
I am a little confused about the flasher. How do I test the flasher, and do I need the the parts from the speedo at all?
The Irish Crew
The auto canceller won't affect the flashing of the turn signals. only abad relay will do this. You can get a cheap car type one from a breakers and use that. Welcome to the forum :waving:.
Discussion Starter · #9 ·
OK, I bow to the supremecy of the board. It was indeed the flasher. After that was changed I now have a seperate problem. The front signals come on, but do not blink. Any ideas?
Not sure if this will be of benefit, but...
When the speed sensor assembly quit on my 1984 Aspencade, the self-cancelling feature of the signals quit as well. The signals would still work but had to be cancelled manually with the switch. Now that I have replaced the speed sensor, the self-cancelling is back working.
G
Hey Heffo :waving:Congrats on yourpromotion to "Active Member" :clapper:You must be well in with some politician :crying:to get that promotion before you had 150 mesgs posted :whip:eek:r maybe you sent a brown bag to wexman.:whip:
:walker::18red::walker:
Discussion Starter · #13 ·
Come to think of it, I am only using two wires. A blackand grey one. I noticed a green one in the area, but didn't think anything of it until now. Do I need a special flasher?
1 - 13 of 13 Posts
