I have an 83 Goldwing Interstate 1100. When I turn on the turn signal in either direction they won't stay on. I have to hold the slider with my thumb throughout the corner and then when I remove my thumb it goes off. I purchased the bike last year and have done this from day one so with winter coming on thought I would spend some time fixing the little problems. Thanks in advance for any help
Mel
The bike has automatic turn signal cancellers like a car. I disconnected mine. Take off the fake tank, you'll see a small black box. Pull the plug, voila.
Hi Chris in va. Thanks for the quick reply. I would like the turn signals to self cancel but not as soon as I release the slider.
You may have a bad turn switch, that will not hold, or your turn signal cancellers needs replacing. 1st Pull the false tank, and see if someone has already disconnected the turn signal cancellers first.
Good Luck,
Nightrider1.
Hi Nightrider 1. When you say "You may have a bad switch that will not hold". Should the slider stay in the direction I push it until it is somehow released by the self cancelling switch or is it suppose to return to center on its own and the actual turn signal bulbs don't go out until a relay somehow turns them out? Sorry, very new at this.
maybe the sensor under the bottom of triple tree is defective or unplugged. the wires run up the steering stem of the lower triple tree. the slider stays put till it self cancels.jb
Hi JBZ. If the slider is supposed to physically stay where I move it to then I must have a faulty slider because, like I say, when I release my thumb the slider returns to center.
if it returns to center even with the keyOFF i would say the switch is faulty. JB
How exactly does the self-cancelling system work? I find that sometimes when I'm sitting at a stop light with the left signal flashing, it will just turn itself off. This doesn't happen all the time, just enough to make me wonder just what's going on.
Thanks.
Greg
