It is everything everyone is saying...at about 30 years of age, the bike is in its retirement stage with arthritis, bad heart and hardening of its arteries, but that does not mean it is the end of life for that poor bike....
....like anyone or anything that age it needs a good going over from wheel to wheel and from the roadway to the top of the windshield.
What that machine needs is a good dose of PM.
Preventive Maintenance.
In general all the electrical must be put back to the 80's, all the hydraulics, mechanical things, air holding elements, fuel holding and carrying all things need to be checked.
Old brittle wires, hoses, rubbers, adapters, tires, battery, light bulbs and every connector, switch, joint must be checked pulled apart to remove rust, green crap, oxidized everything.
The enemy is time, lack of use means more rust and oxidation can settle into the littlest joint and cause intermittent problems.
If you spend the time and go over the complete bike and make sure everything is cleaned, tightened, secure the condition of the bike will go back to the year it was built and a new 1100 was not full of these troublesome stops starts misfits, but it ran every time.
My 1980 Wing is at + 6 years with me. I bought, carted home, dismantled and rebuilt and while I rebuilt it; all the things I discovered that were wrong, because of the 8 PO's work, were corrected upon re-assembly. At least every other year I examine the electrics. The first time is the worst time, since there is no history. But you create a history as you examine that bike. I am going on a trip this Saturday and in preparation and a trial run this old bike is always a happy surprise as it always starts, idles, then runs, never over heats and the voltage is always what it should be.
PM is very tedious and a pain, but when done on a timely basis will keep the bike as young as the week it was assembled but even more important it will not let you down. Honda did a good job with these bikes as evidenced by many 1975 and on being on the road. With a bit of care these geriatric old timers can easily be brought back to a youthful pleasurable driving experience.
As an example in my case it took me about 120 hours to tear down and re-assemble the complete bike and make repairs. Two years later it took a Saturday afternoon to verify things and it takes about 4-5 hours annually to check and test things. Additional maintenance in oil changes and things breaking like clutch cable are of course added but the routine PM becomes less of a burden the more you get to know your wing.
Does this work add value to the bike? To a buyer I think not but to the owner the value of no break downs, no down time, no towing bills, just starting her up and mounting her and going for an uneventful ride...is priceless.
