Any time the key is on my left turn signal is on.The right works ok and the emergency flashers work fine. Any help would be great.
thanks Ron
Is it on as in flashing or just on steady?
Remove the front bulb and see if the light goes off in the rear and on the panel. If so make sure it's an 1157 bulb and look in the socket for the contacts touching each other.
Discussion Starter · #8 ·
Thanks for the info. I found the problem it was in the pigtail the trailer plugs into. I found two wires touching.
thanks wingers
Ron
