1 - 9 of 9 Posts
What's the preferred method, aside from pulling plugs to lessen compression? I'm concerned that using the back wheel might wear the u-joint from 'bumping' the wheel forward to turn the engine.
Either way will work fine. That U-joint has taken a lot of abuse and can stand it. Ever make a bad shift? The U-joint took it. It ain't delicate like me!
Yes, for timing belts and for static timing. The wheel method is kind of awkward for watching the flywheel, also dangerous with bike on sidestand -- almost dislodged it a couple of times! Seems that alternator bolt needs a 17mm box wrench? I haven't been able to get it off.
Mag, either way will work.. Using the rear wheel with the plugs removed is much easier on the drivetrain than a decel down shift. You will be surprised how easy it is to turn that engine using the rear wheel with the trans in high gear.
Twisty
thanks dudes
take the plugs out.
Plugs out and back wheel is really easy, you don't have to bump it with the plugs removed because there is no compression to fight against. Just a nice easy turning motion will do fine.
1 - 9 of 9 Posts
