Hello everybody,
I've bought GL1800 '04 from United Kingdom. They drive left side of the road, in my country, Lithuania we have the right side trafic. Is there the possibility to adjust lights according the right side trafic.
Everdinas
Welcome to the very best goldwing forum on the web.
In Oz, all the goldwings seem to dip straight ahead and not left or right unless your one has a different reflector
Yes you can adjust the horizontal aim of the headlights. If you look down the fork tunnel on the outside edge of each light on the outside and next to the rubber dust boot over the low beam bulb you will see a metal bracket and on the bottom of the bracket is a phillips head screw. It takes a very short mini number two screwdriver and a lot of patience. But the horizontal angle can be adjusted with those screws.
If you need vertical adjustment, you can use a 12 mm socket on a long extension from the bottom and turn the plastic nuts on the wheels of the adjustment motor themselves, make sure the motor is at full up first and then adjust the manual settings.
Kit
Thanks a lot for a quick response! I'll try the horizontal adjustment.
Everdinas
