1 - 2 of 2 Posts
One or two of you might know of the anti dive valve problems ive had over the last few years,,well this week ive had the whole valve replaced,,and what a difference:) the thing i struggled with,, is identifying,,that it is the anti dive,,,,after all, it was only checked and repaired 5000 mls ago,,
i tried every check mentioned to me,,and just sitting on the bike and damping down on the forks,,it appeared that the valve was fine,,also driving off and hitting the brakes ,,,the valve once again seemed fine,, the give away is headlights blowing,,and on a series of very small bumps all together,, it makes the front end go rigid and solid,,making all of the fairing shake and appear loose,, you can feel every hit all the way up your arms and into your body:shock:,,,,i hope this helps out 1800 riders having the same problems ,,and are unsure of whats the cause,,, all the best lads pp
1 - 2 of 2 Posts
