Use GL1500 compressor for tire inflation?
816 Views 6 Replies 5 Participants Last post by  chiefcherokee
has anyone ever done this. what was used for fittings and air line?
There is a fitting in your right saddlebag that you screw an air hose onto, you can get a hose at several of the online accessory stores. Its not really recommended for airing up tires though, you can only run the compressor for a short time before it starts to overheat, just go to Wal-Mart and get one the tire repair kits that includes a little portable compressor.
One of these work well.
But it does work, In all my years I have only used it once. I was in the middle of the Mojave Desert in October I think 1994, and no one was around. It worked great. So, only one experience with it. ;)
I have the same set up on my LTD. All the on board stuff works great, but I cannot get any air out of the hose when attached to air up tires. Any thoughts?
You sure the hose is hooked up (pig tail) to the compressor.
The key has to be in the "P" position.
