Hi folks,
me again,
last time, when I changed the t-belts and the cylinder head gaskets, I went "pristine".
meaning no additives on the gaskets, nor in the rubber ones.
Although probably because of the bike's age a little drop of oil can be seen here and there.
So a friend of mine recommended me to use gasket sealers, for both the cylinder heads and for the rubber seals on the head covers (and t-belt cover).
The question is, based on your experience,
which seal are best to use in each case?
Thank you,
Hi folks,
me again,
Thank you,
