I stripped the threads in one of my heads once. Had to get a helicoil insert to sort the problem. Previous owner must have overtightened the bolts.Be careful with the valve cover bolts. They are very thin at the threaded end and can break.
Hey weewillywing :stumped: Is that the same as a helicopter. :stumped:Had to get a helicoil insert.
:doh::baffled::goofygrin:weewillywing wrote:Hey weewillywing :stumped: Is that the same as a helicopter. :stumped:Had to get a helicoil insert.
Wonderful useful things Helicoils. About the only approved way to fix threads stripped out in aircraft engines. An aluminum casting with a Helicoil fix is better and stronger than the original threads.weewillywing wrote:Hey weewillywing :stumped: Is that the same as a helicopter. :stumped:Had to get a helicoil insert.
