1 - 12 of 12 Posts
yes there is a way to do it. called a Helli coil. most auto parts stores carry the right size. just take your bolt with you to the store . yes it is metric. there should be some instrions in the package , should have a tap , setting tool . drill bit. ido belive. good luck .
· Village Whack Job...
If I recall correctly there isn't a lot of material around those holes. By the time you drill one out big enough to be tapped for a heli coil... there might not be anything left. Might be better to just drill and tap the hole the next size up and get a bigger bolt
· Junior Grue
I've found "Loctite ® Form-A-Thread" works well in situations where there is not enough material for a thread insert or larger bolt.
I'd try re taping it with original size first, can't hurt.
Just before you do this if you haven't already.
Try this.
Put in a longer bolt.
I've done this on a rocker carrier bolt and was about to go down the route of tap and hellicoil then got a tip to try this and low IT WORKED!!.
Cheap and easy to try. The bolts in the head that hold the cover on are not a deep as the holes they go into. You are just using the extra undammaged thread.
As a guide I have driven some 5000 miles on this fix and no problems.
A longer or larger bolt would be hard to find for this application.
I have seen many broken valve cover bolts due to over torquing, but never a striped out hole unless the hole was damaged during the removal of a snapped bolt.
The fact that the valve cover is basicly rubber mounted will allow SOME imperfections in a repair, but the distance from the head to where the bolt goes through the cover will multiply the effects of the hole not being squared.
Bill
2000 GL1500SE
Hi Goldtop, the only problem I see with the longer bolt suggestion on the valve covers is that those bolts have a shoulder on them to keep you from tightening them down too far and maybe warping the cover or otherwise damaging it. Would probably be okay in other applications where a shouldered bolt is not required.
point taken.:dumb:
Guess I'm spoilt by having a shop close buy that sells nothing but bolts and engineering fastenings so getting the right one is a breeze for me.
It's something I forget.
Good luck with the fix and please post an outcome for the ideas posted here and some feedback. Its helps others in the same position.
Ta ta for now.
Goldtop
1 - 12 of 12 Posts
