I had a slow leak in my rear when I first got it, and I went to put some air in it, and I was shocked to see the Valve Stem was about broken in two pieces. Luckily, I was across the hwy from the Cycle Shop, and the put a rubber on on. I have not had any problems since, other than having the rear wheel swapped,( thanks to NightWizard40!) I rode it to cqalhoun NASSIR 1 with a 1 inch small split in my sidewall. I nearly crapped when I seen it after I got home. Now, I go to the cycle shop when I need air, just to make sure that I do not crack in in half on the rear. On the front, I use my home air compressor.
Sincerely'
Nightrider1
