Old School Guru
The 1100s all used the same engine parts from 80 - 83.:)
Gene:waving::11red::11red::11red::cooler:
The Irish Crew
Coot wrote:
Looking for new valves for my project. https://www.partsnmore.comhas the valves listed the same through these years 80-83. Are they the same? ThanksCoot
Well Honda list different part number;
Inlet valve 1980-81; 14711-371-000
Inlet valve 1982-83; 14711-MB9-000
Exhaust Valve 1980; 14721-371-000
Exhaust Valve 1981; 14721-463-770
Exhaust Valve 1982-83; 14721-MB9-000
They will all fit all years, but make sure you get the proper collets (clips) to go with them as they are different as well. The springs are the same for all years.
Alan is right, the valves will fit all gl1100's, but the grooves for the collets were modified a bit, so make sure you get the right collets for the right OEM valves. If you are buying aftermarket, make sure you test your collets are a good fit in the grooves.
Other side of the pond
Hi coot. The posts here are right. One thing you should nots is that the partsmore aftermarket valves and others will take the collets from any year so you won't a problem.
Anyone know where I can buy after-market valves at a reasonable price, partsmore is out. I have found intakes made by vesrah, but can't find any exhaust valves. Thanks for the help, Coot
