Skimming brake discs is not reccomended on a motorcycle disc. The discs are already too thin (compared to a car disc) and don't allow for much meat to be skimmed off. Anyway, the reason they warp in the first place is because of heat (either from old age or more often because the pads wore down too far at some stage). Skimming doesn't last very long because the discs resistance to heat will be diminished at that stage and it will just warp again later on. $25 for skimming plus saytwo hours labour (for the work and running to the skimming shop, also not many shops will skim bike discs for the reasons already mentioned) at perhaps $70 brings it up to almost $100. Even if you do the removal and refitting yourself you have to allow for what your time is worth. Bearing in mind that the disc will warp again in a couple of months you would probably be just throwing your $100 down the pan. You get a warranty with a new disc but none with skimming.
I've had lots of car brake discs skimmed forcustomers in the past (taxi drivers often insist on it to save the expense of a new disc) and I alwaystell themthat unless they are selling the car they are better off with a new disc as they are just delaying the inevitable. They rarely listen and end up buying a new disc a few months later when the skimmed one gives up the ghost again. It was all the go years ago when new brake discs were horribly expensive, but most discs for cars are a fraction of the price of ten or fifteen years back. Just a pity that bike discs haven't fallen in price as well!
Don't be surprised ifmost engineering shops send you packing when you ask them to skim the disc. Most of the ones I know won't touch a bike disc because they are afraid it will overheat and maybe crack or break and perhaps boomerang back to the shop with a lawsuit attached!
By the way, whether you get the disc skimmed or buy a new one, remember to fit new pads as well so to bed it all in properly.
