i thought i would see if its ok the way i hooked it up. i want to see if my alternator is putting out the right voitage. here is what i did. i hooked positve sideof voitmeter to alternator .i then hooked a ground to neg side of voitmeter. i get reading at idle ..about 12.5 to 13.0 at 1500 rpms..about 14.0 to 14.3.i put me a single throw toggle switch where i can cut it off when i want to. the way you showed me with the picture seems to be the best way .if i do another poorboy i will do it your way. the way i got it hooked up won't hurt anything,will it? thanks hoghideman
