Honda does not include a volt meter on the Goldwing and I believe that this is a very important item. It will tell you when a problemsis developing so you can correct it before you end up stranded somewhere. A very nice digital volt meter can be purchased at Walmart in there battery area for $15.95. This meter even shows weither the alternator or battery is malfunctioning. It is easy to wire it in but you'll have to figure out where to tap it into on your bike. I mounted mine with double stick tape on the lower edge of the ignition switchcover running the wires through the joint with the ignition switch cover and the top compartment. You will have to remove the ignition cover to access the wiring to tap into. The Goldwing service manual with its electricaldiagram is handy for this.
