I have seen several post about installing a pore boy altenator that said to install in line a regulator so you dont get battery feed back when the engine is not running. If that is correct, what kind and where would I get what I need?
Ditto, just rip out the OEM rectifier, the alternator has one in it already.
Incidentally the bikes Stator and rectifier are not only anemic, but totally unreliable, the alternator conversion gives you twice the power without any problems.
What about the thousands of Goldwings just like yours that have never had a problem with the regulator/rectifier? :?I certainly have to agree with that. My regulator/rectifier got so hot it actually set the bike on fire.
The diode sounds like it would be great, now what kind and where do I get one?Possible use of a 'Blocking Diode' on the BCL so the battery cannot return power through the alternator, but there is a diode pack inside to prevent that. Unless it's a safety that the designer want you to put in place.
Are you sure that wasn't a generator you had?:ROFL:My 64 Chevy truck had an external regulator, what a PIA it was too! So much better with the built in regulators and electronics!
It's the job of the regulator/rectifier inside your new alternator to prevent reverse current.In my first question I used the wrong word, (regulator) I should have said, relay? when wired up it has a one wire to the battery, voltage goes both ways. when not running, 12 volts go back into the alternator which will burn up something. I think I need something that will break current flow back to the alt. when not running.
My 49 Dodge 1 ton had a generator.Are you sure that wasn't a generator you had?:ROFL:
You may be right, maby what I need to do is volt check my car on the battery feed wire as it is not running.It's the job of the regulator/rectifier inside your new alternator to prevent reverse current.
A fuse is good but many installations forgo this.
Bottom line is that you're over thinking this.
