here is where I put mine
I’ve got a set of hole saws. I could chuck the 2” saw in my drill press. I assumed that the center drill bit would cause the ABS to crack.I used a metal hole cutting saw, that I already had.
it came in a kit of hole saws that I must have bought 40 plus years or more ago.
Greenlee brand.
OR,
it may have been from a kit of Hole Punches from Greenlee also.
I have both. the hole punches do a better job, no jagged edges
Drill a small pilot hole first, then one the size of the center bit. Go slowly. If you have a step bit use it to make the pilot hole. It slices the plastic and won't jam. Make the hole the same size as the center bit.I’ve got a set of hole saws. I could chuck the 2” saw in my drill press. I assumed that the center drill bit would cause the ABS to crack.
One thing about the step bits is you can use them on the opposite side to clean up the burrs.Plus one on the step bits. They are great in plastic. Much better than using a hole saw.
WOWI got big one on Amazon that is perfect for installing gauges and trailer sockets. Goes to 65mm (just under 2 5/8").
LESOLEIL Large HSS Spiral Step Drill Bit - 1/4" to 2-5/8'' Grooves Cone Drill Bit Titanium Coated for Drilling Aluminium Iron Sheets, Wood, PVC Hole Cutting - - Amazon.com
LESOLEIL Large HSS Spiral Step Drill Bit - 1/4" to 2-5/8'' Grooves Cone Drill Bit Titanium Coated for Drilling Aluminium Iron Sheets, Wood, PVC Hole Cutting - - Amazon.comwww.amazon.com
I remember that I almost did it by hand, no drill press.I’ve got a set of hole saws. I could chuck the 2” saw in my drill press. I assumed that the center drill bit would cause the ABS to crack.
I have a set of brad point drill bit that work great for this purpose. The point centers the bit and the cutting edges on the outside of the bit eliminates the plastic fracturing.I remember that I almost did it by hand, no drill press.
that ABS will fracture just looking at it.
thinking back, I am pretty sure, I started with a 1/8" bit, and gradually made it larger with a Step Bit until the Hole Punch bolt would fit thru it
Glad to help. We all need a little memory bump once in a while.I good reminder that I needed to add a battery capacity gauge to one of the golf carts in prep for a LiFePO4 upgrade.
This was poly not ABS so no worries about cracking. Giant step drill made short work of it, since the factory gauge hole is too small.
we also have a Golf Cart that we use as a lawn tug, and the "voltmeter" for it, was purchased 5 to 8 years ago, and is still laying on my office deskI good reminder that I needed to add a battery capacity gauge to one of the golf carts in prep for a LiFePO4 upgrade.
that is a fact, jack.Just make sure you wire it to a switched power supply NOT direct to battery or you will flatten your battery
