· Registered
'81 GL1100
Newbie GL1500 owner. Really like the intercom set up but occasionally it seems too sensitive and will activate from wind noise. Is there an adjustment to desensitize the VOX circuit? thanks Mark in MN
 If you  fiddle with the squelch , and volume controls  it will a bit will help/forums/images/emoticons/confused.gif... If its still  really a problem.. they make better windsocks for the mic cover... I have seen foamy covers that have a half plastic foreward facing  protection, and denser foam ... SilverDave /forums/images/emoticons/emoticonsxtra/cooldj.gif
· Postpubescent member
SilverDave wrote:
If you fiddle with the squelch , and volume controls it will a bit will help/forums/images/emoticons/confused.gif... If its still really a problem.. they make better windsocks for the mic cover... I have seen foamy covers that have a half plastic foreward facing protection, and denser foam ...SilverDave/forums/images/emoticons/emoticonsxtra/cooldj.gif
I've had luck in an open cockpit airplane with wrapping a layer or two of cloth over the mike's foam windsock.
