1 - 14 of 14 Posts
i have an 1 to 4 intake that has a Holley 1940 carb on it have rebuilt it it wont take so i am going to try vw bug carb the intake is the same bolt pattern on it to take a vw carb the problem i have is the studs are straight up the vw is straight down is there a spacer adapter that will allow me bolt it to my intake so i can put a vw carb on it with out buying a new intake
Can you not remove the studs?
Yes on my intake but have no way to tighten the vw carb the nuts will be in the inside of the intake
Can you remove the studs from the VW carburetor...??? Could need some drilling....!!
Then set the VW carburetor down over the studs on the intake, Tighten with a washer and nut....!!.....
I see. You would probably have to make an adapter plate and turn the carb 90 degrees.
The best "Custom" GL1200 I ever saw was done by Phillip Sanford in TN.
I saw it in 1993.in Knoxville, TN.........!!
Yep, it had "one" carb feeding four cylinders.....!!!
one of the holes in the vw carb is to close to the bowl to do that
Discussion Starter · #9 ·
Thank you for your great advice I have fabed a intake from some 1/4 flat stock and a1 x21/2 nipple this is all carbon steel was looking to see it anybody new if there was one that I could get that was a little lighter thank you all very much
Discussion Starter · #10 ·
I also have a problem with my front brakes is there a special way to bleed them just can’t get them to build pressure thanks for any help
I changed my brake lines to braided lines and had problems like yours,I took the line off at the masr cylinder and held my finger over the hole and pumped the handle and then it built pressure and the it pumped up at the caliper
  • Like
Reactions: david_root2000
Discussion Starter · #14 ·
i here what you are saying but out of all tested witch was the best i mean no disrespect i am new with goldwings i just want to get my bike ready to ride
1 - 14 of 14 Posts
