1 - 12 of 12 Posts
has anyone tried to modify the small communicators that you buy at Canadian tire or wallmart to integrate into the gl 1200's intercom system? :12red:
THE GRMS TYPE. just wondering if it can be done
Just another ORF!
I know certain Chapters of my RidingClub use these for the ride Captain and the Tailgunner, to keep in touch with what's going on within the group during a ride, but they have their own headsets and mics, which can be switched around between riders/bikes.
Are you looking at using this as a source of communication between you and 1 other rider that you'll be traveling with?
Or, are you looking for a 'general all purpose communication tool' which will enable you to talk with any other rider?
my wife rides a shadow 600 and she's got a heavy wrist (I'm more layed back) just need to be able to tell her to slow down a little and enjoy the scenery lol. i know they work with head sets , just not sure if there is a way to intergate it to the aspy's intercom
Our shop has wired them to gold wings how ever the PTT button has to be used on the radio according to my techs
i got a set of them cobra hand held cb walkie talkies they work well enough i dont have a intercom system or a earphone set up for them i take one and my brother takes one he usually goes 100mph to my 55-60mph so he just tells me where hes going to stop.
I have the CB on my wing for use with other Goldwings, but when my daughter started riding I tried to hook up an old CB to her bike with limited results. Eventually we started using a couple of FRS radios hung around our necks on a string, it worked OK for us both, and was certainly an easy low tech answer to our communication problem.
Discussion Starter #10
hi unionjk
just wondering about your hand held radios. when comunicating did you receive through the goldwing cb or through the hand helds:12red:
Discussion Starter #11
on my way out the door headed for work , just wanted to say MORNIN to everyone:12red:
I thought about doing this for the 1100, but with the digital display driven by the CB, and rather integrated way it hooks up, I abandoned the idea.
The 1500 looks a bit easier. Looking at the schematic, there are 15 wires hooking the CB up to the bike:
1: MIC ground
2: Headset out
3: CB on (?)
4: Mode In (?)
5: Ground
6: MIC in
7: Speaker out
8: Speaker/Headset ground
9: Mute out (? Maybe enabled when squelch is broken?)
10: Talk (grounded when Talk pressed)
11: Channel up (grounded when Channel Up pressed)
12: Channel down (grounded when Channel Down pressed)
13: ACC (+12V when key in ACC or ON)
14: Back-Up (+12V at all times)
15: Starter reverse switch (supplies +12V when starter pressed)
Assuming the levels could be matched, and assuming you could find a GMRS radio that provided talk/channel up/down (or at the very least, talk) controls, I suppose one could design an interface that would hook it up to the bike and let it appear as a CB to the bike.
1 - 12 of 12 Posts
