1 - 9 of 9 Posts
Need to replace carb #4 after the fuel mix screw broke off and lodged in the carb. If anyone has a single carb available it would be GREATLY appreciated!
J-
Don't know if you want to but it is possible to remove the broken off end of the idle screw from the carb body. I had the same issue and removed it by using a bench grinder to grind a small paperclip down enough to fit in the hole.
Once to the correct size, bend it to a 90° angle and gently work the broken piece out - it will come out all at once so watch the pressure on it so you don't enlarge the hole.
worth a shot at least...
I did try that, Rob. I actually was able to push the broken end out once, but after I dipped, sprayed, dried, and reassembled the carb, the tip broke off the new screw. I wasn't happy. I've managed to destroy the hole trying to get the second one out! :whoops::mad:
Greg1944 wrote:
is 82 the same?
as far as i know the 82 carbsand the 83 carbs are the same. so i believe ---
yep, they are the same. I put '83s on my '80 so I could have the screw out idle jet.
Forum Toolmaster
Forum Toolmaster
HomeBru were you able to find the single carb you were looking for??, If not give me a PM and perhaps I can help!!. ...............................Allan AKA flyboyziel56................
:cheesygrin::cheesygrin::cheesygrin:
1 - 9 of 9 Posts
