Well, I'm not going to go off in a rant about f'in scumbag's that break into your garage and steal stuff...so I will get right to the point.
I am looking for an older style Gerbing's jacket liner (XL) that somebody may want to part with for whatever reason other than it doesn't work. I have contacted Gerbing's and unfortunately, I would have to replace my installed temp controller with the new style (which I think is a bunch of crap!) if I wanted to get a new liner.
Thanks,
Dan
I may have you covered on this - but I won't know until next week - sorry.
I have to get to the item and won't be near it for a few days.
Thanks, pwhoever but that won't work...it would work for connecting my pants to a new liner but doesn't help hooking a new liner to my old heat control.
Let me know, jgbeard...hopefully something comes of it.
Pwhoever
I may be missing something but the one I found above has the female coax connector that should match up to the new jacket and the SAE that should mount to the old controller. In it's description it says: "For Plugging Clothing using a Coax Plug to a SAE Heat-troller" which should be about the same as a Gerbing controller. This is different from theadapter offered by Gerbing that will match up to the SAE connector of the old jacket to a male coaxconnector for a new controller
Here is the actual Gerbing adapter which would not do what you need.
You may be right, pwhoever...I'm definately going to check that out. THANKS!
Then the other one could be used to connect my pants to the jacket.
