1 - 12 of 12 Posts
I need a starter for my 1982 1100A. My stuck starter clutch busted the end housing on the starter and the main ring gear just spins in the housing.
can you post a pic of the broken parts ? i maybe able to help with replacement parts (used) . if no one has a starter.
I need the head end or engine end housing.
1100 starter
I have a good one off an 80. I've checked the brushes-cleaned the commutator and greased the rear gears.
That one appears in the pictures to mount slightly different. How much?
1100 starter
Same as on my 82 interstate.
$75 plus priority shipping.
Starters are the same on all 1100's.
all so the 1000 starter can be used . its just a bit longer in the end cap(brush end) other end is the same as the 1100 . are you sure that you didn`t loose the set pin on the outter ring to starter case?
Discussion Starter · #9 ·
the head end case is busted
Village Whack Job...
Is this what you need?
If so give me a call before 1:am tonight (Thursday) or after 9:am tomorrow(Friday) with your address and I'll drop it in the mail right away and you can cover shipping later. I don't want anything for it, was just going to toss it in the recycling bin. Just cover the shipping cost.
Edit; I guess it would help if I included my friggin number. 414-four 9 one-four 2 zero 3
broke winger
a most generous offer. :claps:
from what i gather in his post`s , that`s what he needs.
Discussion Starter · #12 ·
thats correct. broke winger has been generous enough to send that piece to me. thanks Taylor.
1 - 12 of 12 Posts
