1 - 3 of 3 Posts
I need the air suspension control unit for a 82 GL100 Aspencade. This is the control that sits ontop of the "gas tank" with the front/rear and increase/decrease switch, the one I have is leaking air and you can not order the part from Honda. Any help would be great thanks.
Don't buy a complete control unit or valves from Honda (or used).
You can get the valve stems (same as car tires) from NAPA and replace yours under the control buttons. They are cheap.
I wish it were that simple but the housing the valve sits in is split and leaks there, the part is not avail. through Honda anymore. Thanks.
1 - 3 of 3 Posts
