What happens if I put to much ccclant in rad and coolant bottle.
Is there an overflow from them.
Meath Dragon:waving:
Gregarious Greeter
Yes there would be overflow onto the ground, but this is the fun forum so don't expect a lot of responses.:waving:
Also used distilled water with the anti freeze, because it has no electrolytes in it to cause corrosion in the engine.
Yeah, it will eventually puke out, but it's fairly easy to use a mityvac (or even a turkey baster) to suck the excess from the coolant overflow container.
How is that funny. J/K you should be fine, it will just leak out on to the ground.
hey David ,your picture is fine ,I can see it ,if you still cannot see it hold down ctrl and F5 at the same time and it will then be seen by you , Ciaran
:ROFL:Thanks I thought it was funny as i thought I had a leak.
These goldwings take a lot of know how.
Meath Dragon
Other side of the pond
I usually overfill the bottle by a little bit. If you filled it to the top, most of the excess will go out the overflow.
Hi and thanks
I wont make this mistake again.
Meath Dragon
Must be the luckof the Irish:leprechaun:
Discussion Starter #10
Thanks Choppas.
I seem to be doing a lot.
Since i bought bike.
Hope there will also be a lot of joy.
