I can't see how that hole could be letting water in. It's covered normally with the little lid on the tank pod. Even if the gaskets on the pod were bad I think water would tend to run downhill and drip into the fuel filler tray. That tray has a drain tube.
In order to bend a rod, you'd have to have a significant amount of water in there. I'd think at least a tablespoon or so.
That water, would have to get past the lid, find the hole and drip down past the air cleaner to the plenum, pool up enough to get over the ridge to the carburetor air intake, run into the carb and somehow not sink to the bottom, as water does normally, then overflow into the intake tube and find an open intake valve.
Not impossible, I suppose. But the smart money is on an alternate path.
