Just found about a quart of water in the left side box. I have ridden in the rain
recently but have never had a problem with leakage before. The weather stripping has a small bent spot in the lower front corner, but that seems like a lot of water to have come from there. I removed the tool kit and dried everything out. Don't see any other spots water could have gotten in from. Side box was off recently, when I had the bike in the shop, but looks to be put back properly, lines up, opens and shuts ok.
I am going to try to fix the rubber strip, or replace it. Has anyone done this? What kind of glue should I use? Superglue would be a bad choice if I ever needed to get it off. I am going to try to find the availability of the seal and the pricing.
The box on the other side is dry. The wet box is on the side stand side, so water would run that way. Sometimes I have to park the bike outside, but mostly is lives in a garage.
Help
Help
