howdy to all. just pulled my water pump [broken bearing] but in the process some of
the o-rings and a tin metal collet fell out of the front engine cover. since i don't have
a manual could anyone e-mail me a drawing of where the o-rings go and what the
metal tin i think collet goes to. there is also a wire that goes into the front engine
cover it is covered by a circular mylar washer ? and is screwed down by a brass pin
maybe 1 inch or there abouts in size is this the neutral lite wire?
thx again gumby..
p.s. my intake valves are a gummy mess can i use a cleaner to remove this crap by
spraying into the intake ports before i change the oil??
I heard of people spraying SeaFoam into the intakes on cars, not bikes. I would just do 1/2 can per tank and run it through a few tanks. Also some people run Marvel Mystery Oil added to the oil 100 miles before they change it - really thins it out and gets some extra crud out.
Use an exacto knife or something similar to open the collars a little so they will stay in place.
Use either Vaseline or Crisco vegetable shortening on the O rings to keep them in place.
Make sure you put the neutral stopper pin is located correctly
I presume your talking about the wire in the right side of the first picture, yes it is the neutral wire
Lube the water pump O rings on assy
More info here:
http://www.gl1200goldwings.com/viewtopic.php?f=57&t=4089&p=33767#p33767
