hi everyone, well the " sitting wing" fired today for the first time in a few years. rolled over once and lit right up! Ran REAL slow on full choke for awhile. have new gas , filter and 1 ounce sea foam per gallon. ran real rough till it warmed up and now runs a little rough but wont run on anything less than a little over 1/3 choke. any less and it dies immedietly. has a real lazy pick up when throttled, and the rich fumes will run you out of the garage.when reved up it will pop through the right exhaust on decel. I pulled the gas feed line and let it suck up about 10 oz. of sea foam directly into the bowls. smoked like a leaf fire before I shut it off. How long can I, or should I leave the straight sea foam in the bowls before I start it back up. Do you guys think I,m working in the right direction or do you think I have other problems i should be looking at? I,m not sure which way to go so any help or suggestions would be greatly appreciated.
