1986 goldwing interstate (winebury)
Hi there are thre and were are grease fittings on my 86 goldwing interstate thanks
There are none.
Greasing the splines on the rear wheel hub and the drive shaft are the only grease requirements other than brake pedal and hand levers
1993 gl1500, 1976 gl1000
And then there is the steering head bearings and the swing arm bearings.
Also throttle cable, choke cable, speedometer cable and drive gear.
