Which CB channel do you guys use when at the NASSIR meet?
I usually use 19 on the road.
Gene
Why don't we meet on 19 then go to an agreed upon channel???
If someone wants to talk to me, better get close first. If I can't throw a rock and hit the other bike I can't talk to the rider. Pretty pathetic for a 700 dollar OEM radio. Quite disappointed it it.
How well does your CB work - range wise?
Goldwing Addict :-)
Gene
A lot of us that ride with other Wingers regularly use channel 1, but that varies in some areas and groups.
I should start picking you up about the time I hit Boise. :cheeky1::cheeky1:
Actually it depends a lot on the terrain. If there's a lot of hills or mountains, if you can't see each other the CB is useless. Out in the open you can reach a few miles.
Just one of the guys
I usually figure since the 'Wing is the number one bike, we should use the number 1 channel.
Monkey with a Football
SERRASJ uses 22 most of the time unless truckers are using it for side chats. Then we hop up another one or two.
That puts us near the middle of the band and convenient to 19 when one needs to go back and forth, like when we are getting there or break up and head home.
Believe it or not, But you WILL get futher sending and reception on chanel 12. Thats what most stock antennas are factory set on. Other than That, Why don't we make Channel 1 or 12 the OFFICIAL CHANNEL for NASSIR and every time we ride? There is too much chatter on Channel 19.
Nightrider1
