5581 - 5600 of 5632 Posts
Piaggio MP3, was 02 GL1800
Ok, can someone explain why it inserted both images? I selected thumbnail......
While you are editing the post, click on the big image and hit the DELETE key, it will go away, and just leave the Thumbnail.
I edited your post to make it like you wanted.
Rode to Temple Texas
Reset the torque on '12 steering bearings to 18ft lbs just to see what that was like.
18ft lbs was way too much for this particular '12 Wing.
I thought it was at approx. 15ft lbs before i set it to 18.
Reset to 15.5ft lbs and is a little more tension feel and fish scale pull than it was at 15 and is pretty good now.
0.5ft lb really makes a difference.
I installed the new bearings 31500 miles ago.. Time flies. Now i wish i would have at have at least pulled the top bearing and regreased it.
I understand every bike is a little different so your torque might vary to get satisfactory results.
Too much torque on 88 Wing sucked and harder to work on than this '12 if memory serves me right.
1998 GL1500SE
My 1500 is getting on a bit now, today I treated her a little....
Ordered a new passenger pocket lid - the hinge had snapped and the lid flew away on the motorway.
Did my usual 80 mile round trip to work.
Had the back end hang out coming out of a couple of roundabouts.
Ordered a replacement stereo as mine won't open the cassette lid (or play anything at a volume that can be heard with the bike running) - temporarily fitted a Bluetooth module to the amplifier.
Ordered a new LCD as mine has leaked badly over the summer.
Ordered one of those gear lever mods that's supposed to reduce sloppiness (I think getting a bush made might be a better solution though)
Picked up some parts that were painted (left lowers and trunk lower spoiler) colour match is rubbish and it's really noticeable to me. (Which idiot in Honda decided the lowers should be steel???).
3D printed the missing plastic trim that pushes on behind the side indicators.
Fitted a stainless steel cable to the pannier lid to replace the broken original.
Привет парни! Закончил свой проект по озвучиванию и освещению заднего хода мотоцикла ;)Мне нужно было: Чтобы ПРИ включении ЗАДНЕЙ Передачи рычагом, включалась подсветка заднего хода Goldwing и включалась звуковая пищалка ;)Питание взял от концевика заднего хода. Теперь при включении заднего хода ярко освещается задняя часть дороги и звучит короткий прерывистый звуковой сигнал. Не спрашивайте зачем я это сделал, просто у нас зима, мотоцикл стоит в гараже и мне скучно;)
EDIT: Hi guys! I finished my project on sounding and lighting the motorcycle's reverse gear;) I needed: So that when the REAR gear is turned on with the lever, the Goldwing reverse light turns on and the sound buzzer turns on;) I took the power from the reverse limit switch. The rear of the road is now brightly illuminated when reverse is engaged and a short intermittent beep sounds. Don't ask me why I did it, it's just winter, the motorcycle is in the garage and I'm bored
[QUOTE = "Nitrowing, сообщение: 5956752, участник: 86788"]
Мой 1500 сейчас немножко поправляется, сегодня немного поработал ...
Заказал новую крышку пассажирского кармана - петля сломалась и крышка улетела на трассу.
Сделал мой обычный 80-мильный перелет туда и обратно на работу.
Если бы задняя часть болталась, выходя из пары круговых перекрестков.
Заказал сменную стереосистему, так как моя не открывает крышку кассеты (и не воспроизводит что-либо с громкостью, которая может быть слышна при работающем велосипеде) - временно установил модуль Bluetooth в усилитель.
Заказал новый ЖК, так как мой за лето сильно протек.
Заказал одну из тех модификаций рычага переключения передач, которые должны уменьшить неряшливость (хотя я думаю, что изготовление втулки может быть лучшим решением)
Подобрал некоторые детали, которые были покрашены (левый нижний нижний и нижний спойлер багажника), цвет соответствует мусору и мне это действительно заметно. (Какой идиот в Хонде решил, что нижние части должны быть стальными ???).
На 3D-принтере напечатана отсутствующая пластиковая накладка, которая прилегает к боковым указателям поворота.
Прикрепил трос из нержавеющей стали к крышке корзины, чтобы заменить сломанный оригинал.
[/ЦИТИРОВАТЬ]
Здравствуйте, а можете поделиться моделью пластиковой накладки которую сделали на 3Д принтере? самим файлом пожалуйста)
EDIT:
Translation types
Text translation
Source text
[QUOTE = "Стрелок, сообщение: 5958235, участник: 86221"] Добро пожаловать на форум. Как и когда у вас там сезон катания ??? [/ЦИТИРОВАТЬ] Обычно у нас на Южном Урале мотосезон начинается в середине апреля и до начала октября, климат холодный
[QUOTE = "Nitrowing, soobshcheniye: 5956752, uchastnik: 86788"] Moy 1500 seychas nemnozhko popravlyayetsya, segodnya nemnogo porabotal ... Zakazal novuyu kryshku passazhirskogo karmana - petlya slomalas' i kryshka uletela na trassu. Sdelal moy obychnyy 80-mil'nyy perelet tuda i obratno na rabotu. Yesli by zadnyaya chast' boltalas', vykhodya iz pary krugovykh perekrestkov. Zakazal smennuyu stereosistemu, tak kak moya ne otkryvayet kryshku kassety (i ne vosproizvodit chto-libo s gromkost'yu, kotoraya mozhet byt' slyshna pri rabotayushchem velosipede) - vremenno ustanovil modul' Bluetooth v usilitel'. Zakazal novyy ZHK, tak kak moy za leto sil'no protek. Zakazal odnu iz tekh modifikatsiy rychaga pereklyucheniya peredach, kotoryye dolzhny umen'****' neryashlivost' (khotya ya dumayu, chto izgotovleniye vtulki mozhet byt' luchshim resheniyem) Podobral nekotoryye detali, kotoryye byli pokrasheny (levyy nizhniy nizhniy i nizhniy spoyler bagazhnika), tsvet sootvetstvuyet musoru i mne eto deystvitel'no zametno. (Kakoy idiot v Khonde reshil, chto nizhniye chasti dolzhny byt' stal'nymi ???). Na 3D-printere napechatana otsutstvuyushchaya plastikovaya nakladka, kotoraya prilegayet k bokovym ukazatelyam povorota. Prikrepil tros iz nerzhaveyushchey stali k kryshke korziny, chtoby zamenit' slomannyy original. [/TSITIROVAT'] Zdravstvuyte, a mozhete podelit'sya model'yu plastikovoy nakladki kotoruyu sdelali na 3D printere? samim faylom pozhaluysta)
Show more
1,365 / 5,000
Translation results
[QUOTE = "Nitrowing, message: 5956752, member: 86788"]
My 1500 is now recovering a little, today I did a little work ... I ordered a new cover for the passenger pocket - the loop broke and the cover flew onto the track.
Made my usual 80 mile round trip to work. Had the back hang out, coming out of a couple of roundabouts.
I ordered a replacement stereo system, since mine does not open the cassette lid (and does not play anything with a volume that can be heard when the bike is running) - temporarily installed a Bluetooth module in the amplifier.
I ordered a new LCD, as mine has leaked badly over the summer. Ordered one of those gear lever modifications that should reduce sloppiness (although I think making a bushing might be the best solution)
Picked up some parts that were painted (lower left and lower trunk spoiler), the color matches the debris and I really notice it. (What idiot in Honda decided the undersides should be steel ???).
The missing plastic overlay is 3D printed that adjoins the side direction indicators.
Attached a stainless steel cable to the basket lid to replace the broken original.
Where did you find a replacement radio?
just got back from 200 mile ride,rain,wind,dry,the 1500 still impressess me everytime I ride it.
it has been a good long while, I bought my '98SE in Tampa, FL and rode thru a lot of different Wx conditions, followed the coast a bit, thru Houston down to Corpus Christi, TX where I stayed with a friend for a week....
lots of fun, they had a nice 5th wheel in the back yard, and I was in la la land, they had work schedules, so I just toured all over the Corpus area, saw the big Navy Cruiser docked, wish I had toured it.
Drifted on up through San Antonio, TX to El Paso, TX ( man that was a long, wet, ride.... wore those yellow Frogg Toggs the whole trip..... )
found a warm room with a shower,
then next day, rode from El Paso, TX to home in Mesa, AZ the next day.....
left at Oh Dark Thirty, and got home at Midnight in la la land..... tired, but the bike on Cruise is a Dream.
Much more comfortable than the 1800 I just gave to my son.
I finally got around to taking my rear tire off. It would t have been so bad if it wasn't for the tow part and, the chrome bits and bobs.
No lift table so, I improvised. Getting g it back together is going to be the fun part.
I'm going darkside.
Wheel Tire Automotive tire Automotive lighting Hood
Tire Wheel Fuel tank Automotive lighting Automotive tire
Also, nevermind my channel locks on the lift. That handle has been lost for years
1995 GL1500 Aspencade, 2022 Triumph Bonneville Bobber
Nothing today but thinking about last weekend. Me and 5 other friends rode from Tampa to St Augustine. Not a long trip by miles, but we took our sweet time on 2 lane highways and stopped here and there for scenery and an extended lunch at a FL renowned cafe intended for adults. Did a big loop around Jacksonville on day 2 where we attempted to pay respects at Ronnie Van Zant's grave, but they had just moved him last month. Last day, we rode A1A down through Daytona (bike week hadn't started yet thankfully) and then on home. Was a good weekend.
once home from henry's i moved the Mustang out of the driveway then got a few tools. i backed the Mighty ST 1300 down the driveway then took off the seat, right side bag, and cover then removed the battery. with the new battery, side cover, bag, and seat reinstalled i fired up the bike then rode up and down the block for about a half hour. i wanted to get the new battery installed today cause it might rain tomorrow and the Mighty ST is heading to the shop Wed, i'm loosing fluid for my clutch. i'm starting off the season with 87,836 miles on the clock
Speedometer Odometer Motor vehicle Gauge Tachometer
Wheel Tire Vehicle Land vehicle Car
1987 GL1200 Interstate
I filled it with gas! These days, that's an event.
5.28 Gallons @ $4.499 per, resulting in the most I've ever paid for a fill-up in the bike.
The good news is the price at Safeway dropped 10 cents since yesterday.
1993 GL1500 Aspy 1980 GL1100 STD
Both 'Wings have been completely ignored for almost a month. :( I was two weeks out of town though.
'Posed to be nice on Sunday though, I might have to hot one of them up. 😁
My 1800 has been "ignored by me" since last August, I retired it to my son down in Georgia...
he rode it last weekend
