In my recent post, I had stated after getting bike back from Pistol Petes, the bike was running great other than a minor choke cable adjustment. Would you know it, after putting all the trim and extra parts on the bike, cleaning it and waxing it , ready to roll. I fired it up and.....Damn!!! Gas is coming out of the exaust.....What Now?
are you sure its gas---it could just be condensation ( water ) taste it , dip your finger in it and put it to your tougen . if it is gas open the door , windows , shut it off. quick .
Well, if it's gas you have a stuck float, a bad float needle, a poorly set float height..are the most likely culprits..but check your oil if there is gas in it..time to change it..running it that way will burn youir bearings.
It's Gas, I sent pistol pete a message and I am waiting to hear what he has to say. Lord I hope I don't hgave to break this thing all down again:gunhead:
If Pete's got into the carbs AT ALL,, It's very possible one of the floats has become dislodged from the mount tabs which would cause the needle & seat to lay free in the bowl. A tear down is not neccessary if you can access the fuel bowls..
Thank's I will get on that tomorrow and get back with you. Haven't heard from pete yet.
Sent the carbs back to P Pete. The smoke was the gas getting into exaust. So I have to do the whole thing over again:( Let you know the outcome.
