1 - 15 of 15 Posts
I had the opportunity to trade some wood work for 3 brand new 14" tires and rims for the cargo trailer I built. It had 8'' tires. Anyway, I had intended on mounting the spare underneath the trailer, but the guy I traded with had it mounted there on HIS trailer, and the bead/rim was jammed with little rocks. Enough that I think it could damage the spare if you didn't clean them all out before use. So I opted to mount it inside the trailer, (cartop carrier), way up in the front. That space is kinda useless anyway. I figured no one will steal it, and it won't be exposed to the elements that way. Worked out pretty slick. Pictures coming. jimsjinx
Discussion Starter #2
The rims and tires were perfect! jimsjinx:cheesygrin:
Oh - THAT guy...
Mount it on the bottom of the trailer tongue. Easy to get to, out of the way. That is where mine is, though it sits back under a bit (under the trailer).
You might want to give some thought as to where and how you will store the dirty, muddy, nastytire it replace; should that day come.
This is where we located ours. Not saying that this is where you need to locate yours, just showing an option.
Anti-Guru
I like the "underneath" mounting, a small shiled generally keeps the rocks/gravel to a minimum and it does give ya a place to stash the flat.
However, having the spare UNDER a trailer with a flat is no joy on the soft shoulder of some crappy road (a roll-on axle jack can help, but it's friggen scary sometimes).
to that, holding the spare on or under the tongue seems to address a lot of stuff if you can afford the added tongue weight.
:waving:heres where mine is ---
mounts wiith a square U bolt an nuts. have not dragged it yet. curbs , drive ways or such.
Yeah, that was my first thought. I may move it underneath after all. Hey Pete, that is a NICE trailer! jimsjinx
I would consider a tire carrier on the back of the trailer to help keep weight off the tongue. The only issue would be making the tongue too light when running empty?
Oh - THAT guy...
The tire and wheel is so light that the 'extra' weight on the tongue is probably a good thing, and can be compensated by how the trailer is loaded if needed. Mine is mounted much like WDA-83 wing's. You could use a U-bolt and mount it a bit further forward to make access easier. After all, you need to check its air once in a while, too.
Friend of Bill W.
I took my spare off and set it along side the garage. I carry a patch kit as my trailer tires are tubeless. It seemed to take quite a bit of extra tools to carry to be able to replace the trailer tire. Jack, wrench to remove spare from holder, tire iron or wrench to take off lugs and the spare tire. All extra weight and almost unnecessary.
In the 4,000 miles I have pulled a trailer, I have never had a flat tire.
KNOCK ON WOOD!! :hovering:
Thank you.They have held up well given thier age and mileage. Never had to my spare but I am aware of Murphy's law.
We travel coast to coast and all in between on a bike with no spare . Does a trailer go flat more easily ?
Discussion Starter #14
It's not that one type of tire will get a flat more than another, a puncture is a puncture. But rather, avoiding destroying a good rim cause you were unprepared for a trailer tire flat! I've seen these tires overheat due to a slow leak puncture, unbenounced to the driver, then disintigrate into little road gators! I'd hate to have to hide my trailer in the bushes and then, have to go buy another tire, or worse, have to drag my trailer on a rim! jimsjinx
Here's mine. Helps counter the weight of a full cooler on the tongue.
Are the 8" tires any good? I would have traded you my 12" off this trailer including the spare.
1 - 15 of 15 Posts
