1 - 9 of 9 Posts
Well I am finally going tot install a new radio..HD zoom with remote and high tech stuff..I guess.. ANy this radio requires a all the time hot lead to keep the settings. Is there anyplace besides the battery that is hot all the time on an 81 Interstate. I could go poke around with my meter but I figure someone might know and save me some time.
Be nice if there was a fuse box hotty.
i do belive there is a lead in the fairing plug that is what you need. type 1 & type 2 radios both requied a hot lead to retane radio presets. i dont think it was fused to the plug. so a inline fuse would be a good idea.
That's the big one that is plugged into the fairing on the lower left side..so I have to poke around in the plug to find a hot lead..Or look for a wire in the fairing not doing anything that comes form that plug..just trying to limit my hunting around.
a volt ohm meter should make quick work of that. yes its the big plug on the left side of the fairing. i think the radio hot lead was split off the lead in the fairing. a check of the install manual will tell you for sure where it is split. type 1 or type 2 should be the same ( i think).
OK I thin I have a PFD installation guide at home..not there right now..later today I can check. THANKS
Hi RB, Honda provided the initial power wires for the Type I and Type II Clarion radios in all fairings. If it hasn't been used by a PO for something, coming off the back of the white connector in the left side and tied down neatly under the left glove box should be a short harnass which includes (1P BLK; 2P BLK & 2P WHT) connectors for the OEM radios. These will have a switched hot, an unswitched hot and associated gnds.
Bob Cassel
Should be a light green with black stripe.
Official "Cheeky Plonker"
Left side of the fairing, go behind the indicator, you ought to find some pre-fused spare hots in there, I used them to power up driving lights, cigarette lighter and HID headlight, bottom left of the schematic.
Honda has been very consistant with their wiring codes and colors. If you need a battery hot source for memory, it will be RED in color.
1 - 9 of 9 Posts
