Dunlop touring elite three. Front and rear. Brand new. I have never heard of balance beads.
Dyna Beads are the most popular and can be inserted thru the Valve Stems.
I will NOT run a tire on my bike without Dyna Beads.
www.innovativebalancing.com
this is their product page, 2 oz in front is typical, 3 oz in back.
you can use more and it works the same, try to use LESS and you are Doomed, it will NOT work.
I throw in 3 oz for the front and 4 oz for the back, smooth as baby powder.
Make sure you get the kit that includes the bottle and the Vinyl tubing so you can insert the beads.
Remove valve stem, put stem at the bottom.
put in the proper amount in the bottle,
attach tubing to valve stem & bottle.
use short little squeeze puffs to get the beads to go thru the stems.
takes me about 2 minutes per tire.
IF, for some reason the beads stop going down, use something to tap the valve stem.
