Instead of going "double darkside", Have any of you paired it up with a radial front tire ? Such as would be found on an 1800 since there the same size listing .
02 GL1800 w/Auto Pilot
Not a problem from what I read.
The two tires are NOT on the same axle, which is what causes problems with cars/trucks when tires of mixed construction.
I wonder why you would want to put a radial on the front. There is not really any advantage to it generally but if you stumbled onto the right combination it might work well. There are combinations that work and some that don't and I have no idea why. I have tried a few different brands and types of front tires with my rear car tire and the only one that did not work well was a bias E3 regular front tire, the radial E3 worked pretty well. The rest have been bias rear tires and they work extremely well for me.
