I replaced the disk break pads a few months ago and noticed that both front and rear disks have grooves from the previous owner failing to replace the pads on time.
So at what point should I consider replacing the pads and what should I expect to pay for a front or rear disk? Price of the parts not labor.
If it is nothing but fairly shallow grooves, I would not consider replacing the disc. Those things are EXPENSIVE. And it is not a matter of safety. If the discs are still thick enough, they will work fine. The new pads will quickly bed in to match the grooves and you will have full contact between the pads and discs. If the discs are badly cut up, you will need to replace them, but I would look for used ones. I don't know about the Goldwing, but the discs on my '02 Vulcan 750 are $250 apiece, and there are 3 of them. That is a huge amount of money, and I'd bet that the GW discs cost a lot more than that.
Shallow grooves does not mean the pads were not replaced when needed.
I have yet to see a rotor that isn't grooved. That's why all the brake shops try to talk you into "turning" your rotors when you put new pads on a car/truck. In most cases they don't need that any more than you need to replace the rotors on a bike!
If you wear the pad material away and do damage to the rotors, you will know it from the noise when you apply the brakes.
+1 that you should leave them be unless they are in real tough shape,
RED
Related Threads
Steve Saunders Goldwing Forums
2.5M posts
73.7K members
Since 2004
