Oil coolers are finein engines used for towing, performance or closed in from cooling air, but the Goldwings don't require one.. I've never seen one on bikes even with a side car and trailer. If your's is running hot, there's another problem somewhere that should be looked at. Warm oil is a good thing on Wings so it will carry as much sludge & carbon deposits as possible to the filter and lowest point in the engine block for draining.
If I may ask,, Why do you feel you need an oil cooler?
