Here are some text instructions I acquired somewhere... I'll try to find the drawing another guy sent me and post it soon...
The following was posted on the GWRRA message board on March 03, '03 by Tim Peck. I met Tim and his wife at Pomeroy Ohio and saw his 1500 GoldWing, and unless you were told that he had moved the trunk back, you wouldn't have noticed it. He told us how he did it, sent me an e-mail explaining it, and told me then to feel free to share the info. It weas after this that I moved mine back. you have to move it either 1 1/2" or 2 1/4" or modify the lower rear trunk cover .
The two front holes are closer together than the two rear holes. I used two 1" wide and about 14 1'2" long pieces of 3/16 inch steel to make my relocation brackets, Tom Peck used 4 shorter pieces of 1/4" aluminum, or you could get two longer pieces of 1/4" thick, 1" or 1 1/4" wide aluminum.
The holes that hold the brackets to the bike mounting holes should be done with counter sunk holes, I used 1/4-20 fasteners tapping out the bikes metric bosses. I even added a nut underneath to lock them. One hole very near the end of the strip, and the second 11 1/8" back. Space these holes 5/8" from one edge of 1" wide strip, or 3/8" from the other .... so when the other holes are marked you have metal left.
If you do it with two pieces like I did, just drill the 4 holes to mount them to the bike first, then attach over some long screws in the stock holes, and use a square to mark the new mounting holes 90 degrees off the line going between the two front or rear holes. So trunk is moved straight back.
Measure diaganally, cross measurements should be same (like an "X").
Countersink later and secure, then just mount trunk to brackets.
>>" I have had several guys ask me for more info, so i thought i would post it here for everyone that is interested. There is no bracket or kit to move the trunk back. The first one I did (mine) took me about 6 hrs to figure out with help from a motorcycle internet bulletin board. I disconnected and removed trunk and saddlebags completely. It now takes me about 2 hrs. without removing them. You will need to remove the seat and the trunk bottom cover. Then have someone hold the trunk tilted while you cut off the plastic ribs underneath. You also have to make a couple mods to bike, but they are not noticeable afterwards. I learned on the GWRRA BB that it was possible to move the trunk either 2 ¼” or 1 ½” back. I thought that 2 ¼” was stretching the cables too far, so IMHO, 1 ½” was the way to go. You need to either make 2 long or 4 short pieces for brackets. I used 4 pieces of ¼” thick aluminum (1 ¾”X 2 ½”) and drilled two holes in ea, 1 ½” apart and 9/16” from one side. One I tapped 6mm X 1.0 for factory bolt to thread into and the next was ¼” to allow new longer 6mm bolt to go through to attach piece to framework. By using the 4 pieces, I did not have to worry about aligning the holes in the brackets perfectly (while doing this by myself).
You have to cut away the ribs that are used for aligning the frt mounting holes of the trunk at the factory to allow the aluminum plates to lay flat.
I removed the 3 shortest ribs. Also, you need to cut the sides of the bottom cover at the access hole for the release levers, where they hit a bar under the trunk, (now that it is moved back). You will see where when you go to bolt up the bottom cover. I used a couple washers between the trunk and brackets to make up for the space difference the heads of the bolts made 'cause I did not want to countersink the bolt heads into the aluminum. I also put a couple small washers behind the opening levers bracket to move it a little so you could use the levers w/o hitting your fingertips on the bar. The helmet locks also have to be moved back 1 ½”. You will need to make brackets for them, too. I used thinner aluminum that was 4” X 1 ¾” with a corner cut off to be able to bolt up next to the angled frame. I drilled two holes 1 1/2” apart, the frt one was ¼” (to use the original bolt to attach it) and the rr one was 7/32”. After filing off the small alignment tab, I then attached the locks to these brackets. Some guys don’t use the helmet locks, so they just remove them. The plus for all this is that you can now remove the saddlebags w/o removing the cover under the trunk, since the trunk is now ¼” higher and no more of the complaining about the backrest intruding into Her space!! The usual disclaimers apply, so do this only if you are qualified and have someone to help you. Also, it does not seem to affect the bike handling in any way.
GOOD WRENCHING,
T
