1 - 13 of 13 Posts
88 GL1500
2 ports under the carbs, i have no idea were they went/go. Much Help, Thanks!
323226
I don't think they have overflow ports just drains. You can put a hose on there to keep drained fuel off the engine.
There are 2 4mm tubes that go to them they hook into a 4mm tube in front of the fuel tank, I just got done putting the carbs back in my 89 look by the insulator and you will see the tubes.
323232
It aint rocket science
One hose off each drain to a tee then another hose runs down right side of engine and terminates in the area of where the battery spill hose went.
Question , do you recall seeing orange tag hoses from both sides of each intake(below carbs) going into a T then into a black box on the right side of the fuel tank?
That is the vacuum to the engine control unit, helps regulate timing.
That was a 1988 year thing. Step #13 and on deals with it.
Here's what mine looked like, with the cooling manifold removed.
1 - 13 of 13 Posts
